Re: Tractor
Posted by old on January 07, 2012 at 16:32:17 from (209.86.226.34):
In Reply to: Re: Tractor posted by WV Farmall on January 07, 2012 at 15:17:13:
#1 can be any of the 4 nipples on the cap if the distributor has been pulled and put back in wrong. Get #1 cylinder that one close to the radiator at TDC and look at which nipple the rotor points to. Then go from there. Also when your getting it to TDC on the compression stroke make note of which way the rotor is turning
