Re: Stumped on H 6 volt positive ground
Posted by Owen Aaland on January 07, 2012 at 17:16:00 from (216.47.33.149):
In Reply to: Stumped on H 6 volt positive ground posted by Novice with Case on January 07, 2012 at 08:04:08:
If you have a voltage regulator you should not need to adjust the third brush to adjust the voltage, only for maximum current output. The job of the voltage regulator is to regulate the voltage.
With the battery fully charged, if the charging voltage is not correct, the regulator needs to be adjusted not the generator. The later three brush generators did not have any provision for adjusting the third brush.
