Re: 46 H Steering Wobble - I have the bolster taken apart
Posted by glennster on January 07, 2012 at 17:48:52 from (99.90.9.153):
In Reply to: 46 H Steering Wobble - I have the bolster taken apart posted by ljw on January 07, 2012 at 13:27:54:
best way i found to get the bolster bushings in is to pull them in with a long piece of all thread. i made a "puck " on the lathe witha step in it to fit the bushings, then lay a flat iron across the top of the bolster with a hole in it for the all thread and pull the bushings up and in place. there is a hole for a grease zerk, if you do not get it lined up, just drill a new hole thru the zerk hole in the bolster into the bushing. if you have a sleeve puller with a puck assortment, you may have the right sized one in the kit.
