Re: OH no, time to split the 300u?
Posted by neilc on January 07, 2012 at 18:43:31 from (24.222.155.199):
In Reply to: OH no, time to split the 300u? posted by neilc on December 31, 2011 at 12:48:10:
Okay it's official, I'm an idiot! I took the shifter off, checked things out, there is wear but not as bad as I was thinking it would be. Put it back together and tried it again and I was moving again. Got cold again and 5th gear was jammed again. I pulled it back with the truck and the tires were turning but no go. I cursed a few times and my wife said "didn't you drain the water like you said you were going to?" I knew I did but I crawled under anyway and realized I drained the plug on the trans. but didn't get back to the diff. plug. After a nice hour long fire under it I got it thawed and the fluid changed, well gee it works great now, LOL!
