Have not worked on a C but to me the H is easy to work on because most jobs can be done without having to split the tractor. The transmission top cover is sort of the deck on which you stand and it is easy to remove and gives access to all of the transmission and rearend parts. The clutch disk can be replaced from below without splitting. The rear tires are big, and they are heavy if loaded. Mine are 14.9/38 with calcium and they are very heavy, but they are easy to remove if there is something there like a wall or another tractor to lean them on, or if you have a loader tractor. Zach
