Re: diffrence between an A and B farmall
Posted by Janicholson on January 08, 2012 at 15:59:47 from (67.72.98.47):
In Reply to: diffrence between an A and B farmall posted by craigco on January 08, 2012 at 15:48:58:
That it the sum total
The A lasted through the introduction of the numbered series (mid 50s) the offset allowed vegetable cultivation and was also common with Tobacco growers on the A. The wider stance and tricycle front allowed sharper turns and a with the BN, handier clearance side to side. Jim
