Posted by screwstick on January 09, 2012 at 08:25:33 from (174.24.15.42):
In Reply to: C-60 firing posted by KP2n LA on January 09, 2012 at 08:17:43:
The cylinder are numbered 1-4, front to back. With the front pulley on the timing mark, either 1 or 4 will be at TDC on the compression stroke.
Remove the #1 spark plug and with your thumb over the hole, rotate the pulley till you feel the pressure (compression) building up and continue to rotate the pulley till the you reach the second timing mark. You will now have the #1 cylinder TDC on the compression stroke. With this set, look over to the distributor rotor button, it should be pointing to the #1 tower, or about 1 or 2 o'clock.
This post was edited by screwstick at 08:28:39 01/09/12.
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
