Re: Farmall Cub please Help!
Posted by 504 on January 09, 2012 at 18:45:44 from (64.111.61.44):
In Reply to: Farmall Cub please Help! posted by Farmall-h on January 09, 2012 at 18:21:01:
If you have one, take the plug out of the bottom of the carb, if it doesn t run a stream of gas out then you know where to start looking. The fastest way I have found to quick check is spray starting fluid in the carb and try to start it. If it runs on starting fluid you know it is a gas problem.(1 can is a lot cheaper than burning up a starter.)
