Re: 560 3-point hitch on an M?
Posted by CNKS on January 09, 2012 at 19:04:51 from (216.144.104.128):
In Reply to: 560 3-point hitch on an M? posted by BigTone on January 09, 2012 at 17:51:36:
Width between the axle housing brackets are the same from the C thru at least the 560, and probably higher (656??).
