Re: Mcormick farmall
Posted by Janicholson on January 09, 2012 at 20:02:07 from (67.72.98.45):
In Reply to: Mcormick farmall posted by oldcars on January 09, 2012 at 16:04:05:
I would put it and the mower (because it does not run) at 1500. It will be a good buy at that price if it has good tires. If the tires are poor, maybe 1000. If it was locked up it would be 500 less on all counts. Prime the engine oil through a hex plug on the left rear of the engine before trying to start it. Use a pump oil can and squirt until it builds resistance. They will loose prime and spin bearings. The pump is not accessible from the pan, it requires a split to get to it.
