Re: Farmall Power Steering
Posted by IH fan on January 10, 2012 at 02:48:09 from (108.73.29.81):
In Reply to: Farmall Power Steering posted by IH fan on January 10, 2012 at 00:07:00:
Using your tractor's live pump with a priority flow divider will work if you add a pump for your loader.... live pump will not supply both. I'd use the Saginaw PS pump and mount it higher under the hood... I think I have recently seen pictures on here showing that set-up. You will need to fabricate a bracket for the pump.
