Re: In reply to IH mufflers by Carter Gruenwald
Posted by soundguy on January 10, 2012 at 07:01:12 from (173.105.99.239):
In Reply to: In reply to IH mufflers by Carter Gruenwald posted by Jay Furlong on January 09, 2012 at 19:15:20:
I know at least one guy that welded a plug into the center of a stanley forcing the exhaust to bypass the plug into the outter area, and re-enter the inner pipe, thus going thru '2' baffles.
i believe it was someone here or on the ford board that mentioned it. might have welded a washer or something inthere.. not sure..
soundguy
