Re: Farmall Power Steering
Posted by IH fan on January 10, 2012 at 11:42:17 from (108.73.29.81):
In Reply to: Farmall Power Steering posted by Woody H. on January 10, 2012 at 00:07:00:
Don't do pictures yet, but I doubt the pics from a 240U would do much good. Mine has the pump bracket built off the loader bracket which "wraps around" the front of the tractor, and a shaft goes through the hand crank hole. This pump mounts with bolts to the base of the pump and not the front plate.
If I remember right, the hand crank hole on the H/M series goes through the front bolster at a slight angle??? If that's correct, it would not work very well to drive a pump.
Wardner has some good ideas using an AC clutch on the pump, but if you have 6V, that may not be easy to do.
