Re: IH 80 Snowblower
Posted by 495man on January 10, 2012 at 13:11:19 from (24.137.107.69):
In Reply to: IH 80 Snowblower posted by Harold H on January 10, 2012 at 04:39:31:
There should be a lug on the chute near the base. Attach one end of the cable wrap it counterclockwise around the chute once and then go to pulley on the auger drive side, then to the pulley on the other side, then back to the same lug that holds the other end of the cable.
The cable should turn freely through the pulleys when you rotate the chute by hand, Angle the chute hard to the auger drive side then use a cable clamp to make a loop in the cable for the swing rod. You may have to adjust the cable clamp to get the chute to swing properly.
Been there done that on my 70...
This post was edited by 495man at 13:43:11 01/10/12.
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
