Re: Super C fan
Posted by Lmack on January 10, 2012 at 18:11:58 from (74.190.80.119):
In Reply to: Super C fan posted by Jim in Polk Co on January 10, 2012 at 09:31:26:
Be careful not to run it dry. If you broke the seal by removing the fan blades, it may not seal when you put it back together. I had to use a little silicone to get a seal when I rebuilt mine. Watch when you start up and be sure the fan is not slinging oil. If if is you are going to have to seal up the end.
