Re: Farmall A mag
Posted by gene bender on January 10, 2012 at 20:21:54 from (67.55.227.172):
In Reply to: Farmall A mag posted by James Williams on January 10, 2012 at 18:59:59:
I take the mag off and rotate it to firing position then check if the rotor is lined up with the tower on the cap.
