I stick two bolts through the respective holes in the weight and then lift it up to the hub. If you hold onto the weight correctly, you can support it and push the bolts through one at a time. Once through, the weight will hang on them. Keep one hand on the weight so it does not slide off, and use the other to get the nuts started and then put the other two bolts through and tighten everything down!
Age may play a factor in this method though...I am nice and young so 150lbs is not much of a struggle for me.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
