Re: Rear weights for Super C: Installing
Posted by mkirsch on January 11, 2012 at 05:13:48 from (64.80.110.74):
In Reply to: Rear weights for Super C: Installing posted by Larry Hardesty on January 11, 2012 at 04:29:57:
Lift with your knees, not with your back.
There really are no tricks to it. Just muscle it up there and get the first bolt in. Once you've got that, you're golden.
I've seen guys use forklifts, cherry pickers, etc. to do the lifting.
You can cut some studs from 3/4" all thread and bolt them to the wheel center, nut on each side, to make it easier. Then just slide the weights on over the studs and add a nut. It doesn't look original, though.
