Re: Farmall Cub please Help!
Posted by mkirsch on January 11, 2012 at 05:33:36 from (64.80.110.74):
In Reply to: Farmall Cub please Help! posted by Farmall-h on January 09, 2012 at 18:21:01:
Sounds like the float and/or needle is stuck in the carburetor, and is not letting fuel in.
That happens when you pull the carburetor off the tractor and throw it in a box where it sits upside down and dry for a while. The needle can stick in its seat.
You'll probably need to pull the carb, get the needle unstuck, double-check the float level. Just be warned if you're a carburetor newbie it might take you 2-3 attempts.
