Re: Rear weights for Super C: Installing
Posted by wayne in mn on January 11, 2012 at 06:20:32 from (24.179.165.100):
In Reply to: Rear weights for Super C: Installing posted by Larry Hardesty on January 11, 2012 at 04:29:57:
When I was MUCH younger I put a double set of weights back on my H after painting it. Not any more!!
Make sure you line up the opening with the wheel hub clamp bolts so you can adjust the wheel spacing in the future.
