Re: Rear weights for Super C: Installing
Posted by Harold Hubbard on January 11, 2012 at 06:30:54 from (205.209.16.24):
In Reply to: Rear weights for Super C: Installing posted by Larry Hardesty on January 11, 2012 at 04:29:57:
Call Rent-a-Gorilla, or Gorillas-are-US.
I have very carefully stood them up and caught a Hi-lift jack in the center hole, raised the jack and tipped it until the weight hung on the axle. After that it was just a matter of wiggling it around until I could catch one bolt, then turning the wheel until the other holes lined up.
If you are lucky enough to have forks available, they fit right into the notches on the outside edge of the weight.
