Re: Rear weights for Super C: Installing
Posted by Jim Becker on January 11, 2012 at 06:55:18 from (71.252.156.130):
In Reply to: Rear weights for Super C: Installing posted by Larry Hardesty on January 11, 2012 at 04:29:57:
I've done enough damage to myself lifting things that are too heavy. I now try to avoid it. I made a small hook out of rebar so I can use a chain hoist. My hook is small and the tire/rim would be in the way (especially if turned out like yours were the last I knew). George Willer made a larger fixture for mounting them, as can be seen here.
http://www.gwill.net/Album/Tractors/Farmall/Cubs/57_Scotty/weight2.jpg
You could probably make one out of a piece of rebar that would reach around the rim and still not bend under a 150# load.
In any case, use a hoist, cherry picker or even a front end loader to do the lifting.
