Re: Rear weights for Super C: Installing
Posted by kennell on January 11, 2012 at 09:31:28 from (142.68.119.122):
In Reply to: Rear weights for Super C: Installing posted by Larry Hardesty on January 11, 2012 at 04:29:57:
Larry: I think you'd better send those weights up to me, so you don't hurt anything. LOL
I run a 2x6 or 2x8 through the slot in the hub and put a car jack under both ends of the stick. I then set the weight on the stick and jack it up to the right height. This works good for multi weights which is what i mostly play with. Good luck. Kent
