Re: Rear weights for Super C: Installing
Posted by pete 23 on January 11, 2012 at 17:12:25 from (74.32.238.142):
In Reply to: Rear weights for Super C: Installing posted by Larry Hardesty on January 11, 2012 at 04:29:57:
I can't even lift one anymore, but put many on by my self. You see the farmers would usually put them on the wrong way so you could not get the bolts out to replace the broken ones. Or, when they traded tractors I got to change the wights. Easiest way, have one bolt hole at 12 o'clock, put a long rod through the weight and just lift it up, put rod through that hole and slide weight in. Of course , any kind of a hoist to lift the weight and then the long rod, zip.
