Posted by BMD on January 11, 2012 at 17:30:14 from (24.125.139.102):
In Reply to: Re: 434 3ph posted by agnel matt on January 11, 2012 at 06:31:16:
Good luck... We had a real problems getting the house unit to free up from the two locating pins on the frame.
Also when you put the access plate back on the bottom of the hydraulic unit please make sure it is well sealed. If not it will leak fluid from around the cover into the transmission housing and you will get to take it off a second time.
You can check the chain from the top access cover. You may have to drain the fluid to see the chain. The chain should be enclosed in a couple pieces of plastic tubing to prevent kinking.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
