Re: 706 stuck in park?
Posted by mkirsch on January 12, 2012 at 05:46:59 from (64.80.110.75):
In Reply to: 706 stuck in park? posted by BobHnwO on January 12, 2012 at 05:12:44:
The pivot for the park lever is probably rusted up, or something is rusted up.
Unhook the linkage and see if the lever will move on its own. If not, you found your problem.
