Posted by Zachary Hoyt on January 12, 2012 at 13:14:24 from (184.12.66.170):
In Reply to: downsides to an H? posted by soundguy on January 12, 2012 at 10:53:05:
Look at the bottom of the differential housing under the bull gears, if a bearing fails it will sometimes be pushed by the bull gear right through the housing and the hole will be repaired either with solder or epoxy or some other means. This is not necessarily a deal breaker but it is a big job to change the housing and I would not really want to run a repaired one unless it had been repaired really well. It's pretty obvious if it has been repaired, once you get your head down there. Zach
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
