Re: downsides to an H?
Posted by CoopertownBob on January 12, 2012 at 15:42:59 from (74.51.5.12):
In Reply to: downsides to an H? posted by oldtanker on January 12, 2012 at 10:53:05:
Only thing I would add to this list is to check the torque tube for any cracks running from the opening for the pump, usually the front corners, up around the outside of the housing. This usually indicates overloading without a plate or pump properly in place there. If Parade Duty or Trailer Queen, just weld it, if tractor pulling is on the agenda, it will need replaced with one that is solid, unless you know someone that can weld cast iron flawlessly.
