Posted by CNKS on January 12, 2012 at 17:05:48 from (216.144.104.128):
In Reply to: downsides to an H? posted by soundguy on January 12, 2012 at 10:53:05:
Common problem is jumping out of 5th gear. 5th is direct drive, splines get worn from repeatedly grinding when shifting, or end of shifter is worn. Front end wobble in 5th is common. Clutch and brake pedals may need new shaft and bushings. Pull from side to side to see. Gas tank may be rusty inside causing outlet to plug. All these are not defects, just normal wear after years of use. Make sure the brakes work before backing off a trailer. More of problem with the disk brakes on a Super H, rather than the band brakes on an H.
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
