Re: 3 point for C
Posted by CNKS on January 12, 2012 at 17:27:58 from (216.144.104.128):
In Reply to: Re: 3 point for C posted by freefour on January 12, 2012 at 10:44:07:
The brackets fit in the slots on the axle housings. They have to be from a C or Super C because of the shape of the housings. However the spacing of the brackets, and the spacing of the upper and lower bolts in the brackets are identical on the C through at least the 560. Thus a 3 point from an H or M will also fit, although it might not lift high enough on a C. H,M hitches will not operate off the front rockshaft of the C, though. Best if the C hitch has its own cylinder. I can't tell from the pictures if the hitch will fit. It must be attached to the brackets.
