Re: Rear weights for Super C: Installing
Posted by Rick Remmert on January 12, 2012 at 17:34:05 from (68.103.4.114):
In Reply to: Rear weights for Super C: Installing posted by Larry Hardesty on January 11, 2012 at 04:29:57:
I am using my C to tractor pull. I have the factory rear weights on and off all the time. I will give this a shot without boring everyone. Park the tractor so that two of the holes in the center section are on the horizontal. I then hang the weight on the axle that has a piece of PVC pipe slid over it. The center hole in the weights are oblong. The long side of the hole has a "v" relief cast in it. Let that sit on the axle. You now should be able to put the front or back bolt in by sliding the weight back and forth on the axle. Once you get it thru, snug it up. Then rotate the wheel so the bolt is in the 12:00 postion. You should be able to get the bottom bolt in now. I only run two bolts because I am not going that far. I am also doing this with 2 weighs on each side and I put them both on at the same time. Mine weight between 143 to 148 pounds apiece. I have it down to were I put the 4 weighs on in under 10 minutes and the only lifting I do is from my weight cart and hang it on the axle.
