Re: F12 wide frnt end
Posted by Tom Fleming on January 13, 2012 at 03:02:11 from (206.193.250.146):
In Reply to: F12 wide frnt end posted by 671DKS on January 11, 2012 at 09:54:37:
Yes, the old parts can be built back up and machined back to specs. And yes, if you don't have the right equipment, the results can be as posted. However, a fully equipped machine shop can do the work. The risk of welding and then machining in your home shop is that unless you have an anealing furnace, and some idea of what the iron/carbon/alloy content of the pieces you are refurbing are, you run the risk of hardness beyond what your tooling can handle.
There are many ways to build-up with weld. Spray-gas weld being one of them. Nickel rod/wire is the correct electric weld solution for cast, but there is a very specific process, de-stress, and anealing that needs to occur to remove the brittle/hardness of the weld. You also get an alloy at the weld juncture that may surprise you as to how hard it is.
this is NOT a shot at those of us who can weld and run a lathe/milling machine. Where we fall short is the anealing furnace to properly heat treat and anneal the end result. I have done my own "build up and machine down" work, but I also recognize the limitations of my shop. I have no issues sourcing out work that I know is beyond my skills and equipment. No one here would "stroke" their own crank shaft, but that is exactly what the stroking process is. Build it up, machine it down, heat treat, and finish grind/polish.
Long winded, but it boils down to "if you wanna play, you gotta pay".
