Re: anyone ever see this farmall h attachment
Posted by D Slater on January 13, 2012 at 07:00:16 from (184.15.28.21):
In Reply to: Re: anyone ever see this farmall h attachment posted by Ellis Kinney on January 13, 2012 at 06:49:10:
Yes, saw a couple on M tractors but not a H before. No identification marks could be found on the housings that I could find. Drove one tractor it had a speed between 4th and 5th when engaged. Main transmission had to be placed in neutral when gear box was engaged. Since the trans was placed in neutral the top shaft in trans was only one driven faster by meshing with the 4th slider gear. Bottom shaft that operates the PTO and hydraulic pump was still driven the same speed through the constant mesh gears.
This post was edited by D Slater at 10:58:34 01/13/12.
