Posted by B Becker on January 13, 2012 at 14:50:12 from (66.82.9.92):
I am currently putting new bearings and seals in my Super C transmission and have run into a couple of issues I am trying to remove the spline shaft and according to the IT manual, I am suppossed to remove the pin from the reverse gear. Do I use a punch to remove the pin? What do I replace the pin with when I re-install the shaft? On the lower shaft, the nut on the front came loose and popped a hole in the Bearing retainer. That explains why there was hardly any oil in the rear end when I pulled the plug. Where can I find a replacement bearing retainer? IH doesn't make them anymore.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
