Re: Radiator fluid question
Posted by Janicholson on January 13, 2012 at 17:26:10 from (67.72.98.45):
In Reply to: Radiator fluid question posted by BigTone on January 13, 2012 at 07:56:02:
The level should be down about half way to the cores when cold. There is no expansion tank, so topping it off is no good. Do not keep refilling it unless it has issues with overheating. Jim
