Only if you were planning on running the new pistons directly on the bores, if not, JB the crack, let dry overnight, then sand/grind out the excess and install new sleeve, using some glycerine (local Mom & Pop style drug store) as a lube/sealant, but be quick to get it installed once you apply the stuff, because it will set up tacky in less than a minute. You may need to use substantial force to seat the sleeve all the way to the bottom. Try a block of wood and a sledge hammer. I have been running mine this way on number one since '09 with no problems at all, and I even tractor pull with it. The block can also be welded, if using sleeves again or not, as well, but will require boring afterwards. Might be a good time to bore that sucker out to what you think is a good size, then have custom sleeves installed in it, but this can get expen$ive. :P
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
