Posted by The tractor vet on January 13, 2012 at 18:12:43 from (76.212.224.69):
In Reply to: 656 PTO posted by ONT 656 on January 13, 2012 at 14:17:27:
First off to save you time and money find someone that has the test fitting and a gauge to check pressure , if it is low then crank up the pressure to around 215- 230 and see if it holds . If it still slips then it is time for a clutch pac. The hyd. oil all comes from the same place so your good to go on that . You can also just try loosen the lock nut on the valve stem and give it a couple turns up into the linkage nut . But i would rather ya had a gauge on it before you just crank it.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
