Re: 656 PTO
Posted by LEfarmallh on January 13, 2012 at 20:11:55 from (67.54.200.143):
In Reply to: 656 PTO posted by ONT 656 on January 13, 2012 at 14:17:27:
The linkage on the 656 pto has a problem with breaking over center. If you have a gauge on it this will be easy to see. It will go up to the correct pressure as you pull up on the lever and as you reach the top of the stroke you will loose pressure. I cured this by welding a 3/8 nut to the side of the linkage just above the plunger. Then you can put the proper length bolt in it so that hits the frame of the tractor at the proper location. Put a jam nut on it and you are good to go. Even after a rebuild I wasn't able to maintain pressure until after I did this. Hope this helps.
