Farmall C charging question
Posted by Dave BN on January 14, 2012 at 05:43:02 from (64.12.116.73):
My C wouldn"t charge the battery on "high charge" so I adjusted and cleaned the contacts in the voltage regulator. Now it charges on high and stays there-amp meter shows +10 all the time. If I open the contacts on the voltage regulator it goes to 0 or -10. Looking at the poor diagram I have I don"t see how it would charge at a low rate. Doe"s anyone have a wiring/charging diagram for a C with voltage regulator and battery ignition? Or does anyone know what allows charging on a "low" rate.
Thanks
Dave
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
