Re: M-No fire to Plugs
Posted by gtski on January 14, 2012 at 12:05:25 from (4.131.23.91):
In Reply to: Re: M-No fire to Plugs posted by Janicholson on January 14, 2012 at 10:32:20:
That's what I was trying to say. Isn't the purpose of the ballast resistor or internal resistance in the coil to keep the point voltage around 6 volts and the bypass wire to give higher volts for starting?
