Re: Super M Charging Question
Posted by Brownie 450 on January 14, 2012 at 12:56:30 from (66.43.241.198):
In Reply to: Super M Charging Question posted by WI-Ed on January 14, 2012 at 10:57:59:
Best way is with a "hold against" amp meter. These check charging current by holding them against the wire. You don't have to break the circuit to check charging current. I also use an ammeter with a short 2-wire cord with alligator clips on the ends. This requires pulling a wire somewhere in the circuit & attaching the clips to read charging current.
