Re: How if the bearing splitter used on the front pulley?
Posted by gene bender on January 14, 2012 at 16:00:00 from (67.55.227.172):
In Reply to: Re: How if the bearing splitter used on the front pulley? posted by Red Dave on January 14, 2012 at 14:29:19:
I just cut a circle the dia of the pulley and then the u-cut so it would slide ofer the hub and a three jaw puller and have pulled a bunch of them sometimes i do use the torch to warm up the hub as some sure seem to be harder to remove than others same with the set screw. I have a thingy made to press them on with a jack.
