Re: Zachary Hoyt are u there
Posted by Janicholson on January 14, 2012 at 21:23:53 from (96.24.99.126):
In Reply to: Zachary Hoyt are u there posted by ajdeereman on January 13, 2012 at 10:51:48:
The ball bearing should be held solid by the step in the gear box front hole, and the big plug. The bearing is the sole endplay control for the worm. If the worm is moved outward toward the front of the tractor by putting a shim under the ball bearing, the worm will be operating on a patch of the worm that is new to the sector. Not much, because there are limits to the extent to which this can be taken. Be sure the entire travel of the gear is not binding. I do not know how much additional life is generated this way, but I suspect the wear pattern is not as "correct" as it was new. But it is worth a try. Jim
