Re: How if the bearing splitter used on the front pulley?
Posted by JRSutton on January 15, 2012 at 06:11:36 from (75.130.109.233):
In Reply to: How if the bearing splitter used on the front pulley? posted by W.Brehm on January 14, 2012 at 14:00:49:
Probably goes without saying - but if you're using any kind of puller with a thread - threaded rod or whatever, make sure you grease the threads good first.
It's one of those things that gets ignored quite often, and it can make a HUGE difference in how much pulling force you get for a given amount of crank force.
Not only does it make it easier, but it'll give you a lot more force before distorting threads.
