Engine Bearings
Posted by Jim Paterson on January 15, 2012 at 11:25:51 from (107.5.116.86):
I have the crankshaft out of my '44 H and measured the journals and they are 2.49 (which the shop manual shows as standard). The journals are in great shape (very clean with no scratches or gouges). Am I good to just order new standard bearings without doing any machining to the crank? This tractor is for fun only and will not do any work (it probably won't see 10 hours per year). Any advice would be helpful. Thanks.
