Re: Starting 560
Posted by Rich on September 07, 2000 at 16:20:30 from (209.216.130.6):
In Reply to: Starting 560 posted by Sam Comstock on September 07, 2000 at 15:50:48:
Sam: You did not mention if you preheated the engine with the glow plugs. If you are gettting smoke out of the exhaust pipe,you are getting fuel to the cylinders,although you may have to bleed the fuel line a few times in order to get all of the air out of the fuel system. I do not suggest you use ether with an engine that has glow plugs as this can cause major damage. If glow plugs are working, preheat engine for approx.1 minute and then hit starter. Good luck
Post A Followup
: Re: Re: Starting 560
