Re: Farmall 450 Gas Tachometer plastic gear
Posted by farmallhal on January 15, 2012 at 14:40:36 from (71.49.65.127):
In Reply to: Farmall 450 Gas Tachometer plastic gear posted by Tony_Idaho on January 15, 2012 at 11:57:32:
Tony, my TC-53B parts catalog for my Farmall 240 shows the part no. for that part as 369695R91. Don't know if it is plastic/nylon or metallic but is noted as having 32 teeth. I do have a drive unit from a Farmall 404 (a later tractor then the 240 which uses the same part nos.) and the gear in that unit is non-metallic also. I don't have any confirmation that the part went from plastic/nylon to metal as noted in another post on certain models or on a certain date. Hope this helps, Hal.
