Re: Re: Re: Tire size
Posted by Andy Martin on September 07, 2000 at 16:27:08 from (38.31.74.251):
In Reply to: Re: Re: Tire size posted by Wardner on September 07, 2000 at 12:12:15:
I'm changing my story.
I went out and measured ground to c/l alxe.
I was real surprised to find that my H with narrow rims and 14.9's is only as tall as my M with wide rims, and 14.9's. I see that the the narrow rim makes the tires look goofy but between the two tractors there is not noticeable differences in axle height: 29-3/8 inches.
The M does have three wheel weights each side and the H probably has less air pressure.
Other radaii I measured on H's were 27 inches for a 12.4 on narrow rims and 26-1/8 for 11.2 on narrow rims.
So my tractors are seeing a 12-1/2% increase in speed and decrease in power going from 11.2 to 14.9. 14% still sounds plausible for going to 15.5.
I like big tires on wide rims.
My two cents' worth.
Post A Followup
: Re: Re: Re: Re: Tire size
