Re: How if the bearing splitter used on the front pulley?
Posted by farmallhal on January 15, 2012 at 14:54:07 from (71.49.65.127):
In Reply to: Re: How if the bearing splitter used on the front pulley? posted by sflem849 on January 15, 2012 at 12:59:33:
I believe the reason for the plate very gear pullers is the plate gets behind the center hub of the pulley whereas the 3-jaw gear pullers break the outer flanges off the pulley, Hal.
