Re: IH 464 Coil voltage?
Posted by hayray on January 15, 2012 at 14:59:12 from (173.121.44.151):
In Reply to: Re: IH 464 Coil voltage? posted by gtski on January 15, 2012 at 11:23:48:
I gonna check that wiring diaghram because when I take the 12 volts away while it is running it stalls. I placed a jumper cable from the battery to the coil while I had the resistor hooked up on the wire from the key to coil.
